632Views8Replies
Author Options:
My Arduino countdown timer will randomly start subtracting by tens when its set to ones why? Answered
I made a little small scale hydroponics system controlled by my Arduino mega it's supposed to count down from 300 seconds (5 mins) and when it hits 0 activate a pump for one minute then reset and do the cycle all over again. But after a couple of cycles it will randomly start counting down by tens or hundreds. Here is the code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int pump = 53;
int time = 300;
void setup(){
  pinMode(pump, OUTPUT);
  lcd.begin(16,2);
  lcd.print("PLANT WATERER =D");
  delay(5000);
  lcd.clear();
void loop(){
   if(time == 0){
  lcd.clear();
  lcd.print("WATERING");
  digitalWrite(pump, HIGH);
  delay(60000);
  lcd.clear();
  lcd.print("FINISHED");
  delay(800);
  lcd.clear();
  digitalWrite(pump,LOW);
    (time = 300);
(time --);
  delay(1000);
  lcd.setCursor(0,0);
  lcd.print("watering in:");
  lcd.setCursor(0,1);
  lcd.print(time);
Help would be greatly appreciated. thanks a bunch:
     Harry
mpilchfamily
mpilchfamily
Best Answer 6 years ago
One problem may be that you have the time -- and time = 300 in parentheses. No need for that. Also moving the time-- to the end of that LCD update may help too.
Here is another way you may want to code it. I prefer to display things on the screen before delaying and before changing the count. Then you have the full 300 seconds displayed.
int pump = 53;
int time = 300;
void setup()
lcd.begin(16,2);
delay(5000);
lcd.clear();
void loop()
if (time > 0)
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(time);
delay(1000);
time --;
else
lcd.clear();
delay(60000);
lcd.clear();
delay(800);
lcd.clear();
time = 300;
harry88
harry88
Answer 6 years ago
It works!!! =D Thanks a bunch you were a huge help.
mpilchfamily
mpilchfamily
Answer 6 years ago
Did you make changes to your original code like i suggested or did you use the code i posted?
During the countdown portion it would be a good idea to clear the screen before setting the cursor and printing anything on it. What your seeing may be the result of a miss alignment of characters as it prints over the existing characters.
harry88
harry88
Answer 6 years ago
I used the code you posted. OK thanks I'll edit the code when i get a chance today.
harry88
harry88
Answer 6 years ago
OK now with one more "lcd.clear();" the program works great thanks a bunch to mpilchfamily, and steveastrouk for the help.
steveastrouk
steveastrouk
6 years ago
Does it screw up if the pump isn't connected?
harry88
harry88
Answer 6 years ago
It screws up either way I have the Arduino hooked to a mosfet hooked to the pump.
