74Views1Replies
Only up to four LEDs light up.
I've got loads of LEDs and resistors from eBay and using the resistors, only up to 4 LEDs in serial will light. I can't just use more resistors, as I broke open a mains lighting bulb that uses 20 LEDs to provide lighting. Looking at the printed circuit, they are all soldered in series. If I put + at one side of an LED and - at the other with these resistors I have, it lights, two three and 4 work, but on the 5th, it drops dim, after that it won't light at all. Do I need a different resistor, of is something else wrong. Could someone kindly tell my what resistor I need for 20 5mm White LEDs running off 18v (two 9V batteries), and 9v (one)? Thanks! Josh.
12 years ago
well, the resistors you probably got are 560 ohms and used with a 12 volt power supply to light 1 led, the more in series of LEDs the lesse resistance you need. If you have 4 LED in series you can actually put 4 of your resistors in parallel to get 1/4 the resistance.
well, since white has a voltage drop of 3, 18/3 equals 6, and for simplicity lets just put sets of 5 together.
so 5 LEDs, that'd be 18-15= 3, 3 X50= 150 ohms, so for 5 in series hooked up to an 18 volt power supply you'd need a 150 ohm resistor in series.
So if you have 4 sets of those in parallel (you have to use a seperate resistor for each set of series, do not use 1 resistor to drive all 4 sets of parallel's) then you'd have 20 white LED's lighting up
