724Views4Replies
Author Options:
Screw broke inside ikea beddinge how to get it out? Answered
One of the screws that holds the bottom frame together (long metal bars) broke inside the bar, its about 2-3 mm inside and i cant get pliars or anything around the screw to pull it out. Anyone else have come across this and have a potential solution, I'd be very appreciative!
FarmerKJS
FarmerKJS
5 years ago
If it is wood you can get a Screw Extracter as kelseymh mentioned.
If it is metal you may need to drill out the screw and tap the hole
Wired_Mist
Wired_Mist
Answer 5 years ago
I've bought ones of these, it's definitely Metal.
drill the screw out and use a self taping screw that is slightly larger then the original.
Vyger
Vyger
5 years ago
Why do you need to take it out? Just leave it there and put in another one next to it.
A picture of the problem would be most helpful.
kelseymh
kelseymh
5 years ago
You need a tool called a "screw extractor." They come in many diameters, depending on the size of screw/bolt you need to remove. You can easily get one (or a set) at your local hardware store, or order one online (Google, Amazon, whatever).
