81Views3Replies
Author Options:
The parts needed to build a solar powered light? Answered
Hello everyone,
I'm trying to build a solar powered led (2nd part would be to add a USB port) and I'd like to know all the parts I need to get it working nicely.
Apart from the obvious things like an led, battery, on/off switch, wires and solar panel will I need some sort of controller for charging the battery as well as not overcharging it?  I'd like it to have a 1W panel, a 1W led and battery which can run the light for 5 hours (so 5Wh right?)
If it is easy enough I would like to build one which has a USB port as well so I can plug in my USB fan.
Thank-you for reading.
mpilchfamily
mpilchfamily
7 years ago
If you want easy then buy a solar charger with built in battery and USB port then add your light to it.
Full Metal
Full Metal
Reply 7 years ago
Yes, that would be the easiest way : ) but I actually want to build it myself from the base parts.
