9572Views7Replies
Author Options:
What could I do with an old, broken ps2? Answered
My friend has a bunch (like 3 or 4) old broken ps2s and he's willing to sell them to me for $5 each. I can't ignore this opportunity. I <3 opening things up etc. I'm 14 and I like taking stuff apart to see how they work. If I bought one of the broken ps2s and I couldn't fix it what do you suggest I do with it? Are there any useful parts inside? Could I squish a mini-itx board into it? (It's the old, fat ps2, not the slimline). Do you know of anyone that has fiddled with a ps2 in such a way?
Tags:ps2
gmxx
gmxx
Best Answer 12 years ago
A computer inside would be awesome. a mini-itx board should fit, as long as a slimline cd/dvd drive and laptop hd were used, along with a pico psu or external power supply. if it all doesn't fit in one case, then you could always drill a hole for the wires, and then use two stacked ps2 case to make a bigger case.
Bardouv
Bardouv
11 years ago
Hammer smash!
11010010110
11010010110
12 years ago
4 bad ps2s --> up to 3 good ps2s. open them and start swapping parts you can mod a pc computer into a ps2 case - possibly using the existing cdrom drive
countable
countable
Answer 12 years ago
I doubt it, normal PCs need a 44 pin IDE cable to connect to a disk drive, and sony didnt need to do that since they only needed to read info off the disc as opposed to burning a disk too. You could still get a slimline dvd drive and put that in place?
11010010110
11010010110
Answer 12 years ago
can you hack a pc drive to work with the mechanical parts of the ps2 drive ? (so that electronics etc are from the pc drive)
snowpenguin
snowpenguin
Answer 11 years ago
No. It is the laser that is different from a Write or Read drive. Plus, why go to the work of swapping out parts between drives when you can just mount the Write drive in?
Matt21497
Matt21497
12 years ago
OOh i have a good idea FIX IT
Joe Martin
Joe Martin
12 years ago
I've still got the case from a broken one somewhere that wll be used once my PC with the mini-itx board comes back. See www.mini-itx.com for some ideas
Pyrotechnic-Robot
Pyrotechnic-Robot
12 years ago
ship it to me also you could put a computer in it after you gut it. If you can re-program it, you could boot linux on it.
