7675Views4Replies
What happens when you connect capacitors in parallel and series?
Does it raise the voltage rating if connect in parallel? I am going to be usin the capacitors for a coil gun, so I want the maximum voltage without having to buy bigger caps. Thanks
8 years ago
The energy in a capacitor is expressed as ½ C V2. To keep the math simple I will use Farads instead of the usual microfarads. The charge, Q, takes the form Q=CV. Since our C is in Farads we can use integers. These formulas are unchanged even if C is in microfarads (uf. 10 to the minus 6th of a Farad) or even smaller terms. For our example we will use a 10 Farad capacitor charged to 10 volts.
The energy in that capacitor is ½ C V squared or 5 * 100 which is 500 joules. We have a second capacitor with no charge but also 10 Farads. We connect the two together in parallel and we now see 5 volts between the terminals. Our 500 joules now occupies 2 capacitors totaling 20 Farads and we see 10 (½ C) times 25 equals 250 joules and 250 is missing.
In the normal sequence of things our textbook tells us the small resistance of the connections between the capacitors ate up the power. At first glance this seems satisfactory. Probably why it is the official answer. It fits as a plausible answer.
However
Energy in a capacitor is 1/2*C*V^2 or equivalently 1/2*Q*V . The familiar first expression tells us energy is proportional to the square of V, the second formula that energy is also proportional to the charge.
If we double the number of plates in our capacitor by attaching another one in parallel, the charge halves with the equivalent capacitor resulting in halving the voltage. If we allow the electrons on the plate to halve their density the electromotive force halves as the electrons leave. So that force of 10 volts becomes 5 volts. But energy is proportional to the square of V so halving the voltage reduced the power. Nothing was lost in a resistance to show up as heat. V halved, energy halved. If you could reverse the charge distribution to the original 10 Farad condition you would have your 10 volts back and the energy reappears. Unfortunately you would have to do work to push the electrons back onto their former real estate. Rather like a fountain that flows from an elevated pool and when it reaches bottom is pumped back to the top pool. Work is done to lift it but downward fall is free.
8 years ago
Good question but when I made my cap bank in series they did not charge but it may have just been me :/
11 years ago
capacitance goes up or down.
11 years ago
The voltage stays the same in parallel, adds in series. I had the same problem you describe when I was building tesla coils.
