76Views5Replies
Author Options:
What tools do I need to change a tire on a ten speed bicycle ? Answered
Tags:bike
seandogue
seandogue
3 years ago
An appropriately sized wrench to remove the tire and rim, (probably 1/2", 13mm, 14mm, or 9/16") and then the tool iceng outlines. Those come in tire repair kits you can pick up for a few bucks at a bike store or a bit less at Walmart and the like. Obviously you'll also need a pump or air compressor.
rickharris
rickharris
3 years ago
Technically - an adjustable spanner, 2 forks or spoons and a pump.
iceng
iceng
3 years ago
I used these to change my tires in the past. There are fat plastic versions I don't like.
You use these as pry-bars anchoring them to a spoke, then using the second one and then the third releases the second which becomes the third etc until the tire is off the rim..
iceng
iceng
Answer 3 years ago
Oh yea,
Click the pic to view the whole image..
bwrussell
bwrussell
3 years ago
There is a little plastic flat blade tire changing tool that you can use to get the tire on and off easier. Any bike shop and probably most places you can buy a tire will probably have one, if there isn't one included with the new tire.
Mostly you just don't want to pinch the tube with the tire wall.
