308Views4Replies
Author Options:
Which electronic component to use to step down voltage from 7.4v lipo battery to varying output voltage between 3v - 6v? Answered
Hi all,
I dont have much knowledge of electronic components and I am trying to make a robot. I have servos with operating voltage of 6v and I will be connecting it with a battery. I am not able to figure it out which electronic component should I use to step down the voltage from 7.4v lipo battery to have varying output between 3v-6v with maximum output current of 2amp.
Thank you in advance for your advice :)
PiyushJ15
PiyushJ15
Answer 4 years ago
Thank you for the reply. My other concern is I will be using wireless transmission between arduino using Zigbee module so the device what you suggested has coil on it which will hamper the signal transmission between arduino. I am planning to use LM317T, what do you think on this ?
steveastrouk
steveastrouk
Answer 4 years ago
If, as you admit, you have little knowledge of electronics, take advice when it is given. Yonatan is quite correct. That device is an excellent choice. An LM317 will burn a lot of power for no reason.
-max-
-max-
4 years ago
Easiest solution would be to buy one of those buck converter boards on amazon. Most/all of them use (in some cases knockoffs) the very popular LM2596 simple switcher chip.
