212Views16Replies
Author Options:
Which ones better: Mezak or Oodasault(any version)? Answered
I like the way they both load, and fire, but which one is better in range, accuracy, power, and all that other stuff?
TheDunkis
TheDunkis
Best Answer 11 years ago
Well it depends. I think they get similar ranges with similar bands but with more ammo mine will have more mag pressure when it's full although it should improve as you fire off more shots. They both should be just as accurate too. If you plan on staking more than 4 rubber bands on then go with the MeZak. Mine uses a lot of black Ys. The MeZak uses wheels on the handle for the best comfort. My magazine locks back. You're going to need to put your other hand in front of the magazine for 100% reliability. That's not an issue for me but it has been for others. They both perform a lot similar.
If you have enough pieces, build both and compare yourself. If you don't then seeing how they're rather simple builds just make one first and then the other and see which you like better.
chopstx
chopstx
Answer 11 years ago
What about your first version on Ibles?
TheDunkis
TheDunkis
Answer 11 years ago
The only advantage that has is pieces over both guns and reliability over the V3. You can use clips for it but it's a little harder and you can't really add ammo to a half full magazine.
chopstx
chopstx
Answer 11 years ago
Cool. Thanks!
chopstx
chopstx
Answer 11 years ago
Ok, thanks!
Knex Lego Maniac
Knex Lego Maniac
10 years ago
id build both and compare them for yourself that is what i plan to do not to mention building them will help expand your knex building creativity and ideas i try and learn from all to better improve my guns and come up with new ideas
chopstx
chopstx
Answer 10 years ago
Thanks and your right.
Knex Lego Maniac
Knex Lego Maniac
Answer 10 years ago
no problem you should check out TheKILLMeZak gun i just put up a forum and posted a vid on youtube see it here http://www.youtube.com/watch?v=3DoCIkfMSxU
chopstx
chopstx
Answer 11 years ago
Ah.
DJ Radio
DJ Radio
11 years ago
Oodassault.  It has bigger mags, no wheels, and no cut parts.
chopstx
chopstx
Answer 11 years ago
Cool.
Fred the Penguin
Fred the Penguin
11 years ago
mezak is better structurally, so if you want power, range and accuracy build a logic bow (I mean mezak)
chopstx
chopstx
Answer 11 years ago
Lol.
cj81499
cj81499
11 years ago
Oodasault because then u dont need to mod piecez
chopstx
chopstx
Answer 11 years ago
Thanks.
