348Views3Replies
Author Options:
Will an ATMega88 compiled program work on an ATMega32 ? Answered
I found a nice hex file for the ATMega88 but all i have is an ATMega32 ... will the hex made for the 88 work on mine ? Or is there at least a converter which will make the hex file be compatible with the atmega32?
S1L3N7 SWAT
S1L3N7 SWAT
11 years ago
It should work fine, as long as it's not to big for the chips memory. You will probably have to modify it if the pins on the AtMega88 are not the same on the 32.
Vladmakesstuff
Vladmakesstuff
Answer 11 years ago
actually the software i found outputs data on PORTD , which has the same pin count as the atmega32 (8 pins on Port D) ...so i guess that if i load the program into the mega32 it should run it ...
S1L3N7 SWAT
S1L3N7 SWAT
Answer 11 years ago
Yeah, it should have no problems.
