101Views3Replies
bike light design help
im trying to design a new light for night riding im using a 7 led array in the neighborhood of 1500lm with a 30deg wide beam of light but ive hit a bump in the road and would like some guidance in it so far my pictures are only a rough draft per say
6 years ago
after a night of little sleep lense retention ring, cut in heat sink
6 years ago
I guess look for flashlight/torch optics designs. Maybe just take the head off of an existing commercially built tactical flashlight/lamp to see that it does have a glass or plastic lens element to focus the beam. Look up any "LED calculator" to figure out how to configure and power your array of LEDs. You would have look through the specs or datasheets of available LEDs to see if you get the output you want. Maybe a single element LED would do instead of the 7. High power LEDs do require a driver board so you don't burn out the LED and you would have to take heat dissipation into account for the enclosure. Mounting options are many from fixed to variable with tube or handlebar mount. Good luck.
6 years ago
the lense
http://www.luxeonstar.com/khatod-30-degree-40mm-7-...
the led
http://www.luxeonstar.com/cool-white-5650k-7-led-4...
controller
http://www.luxeonstar.com/700ma-external-dimming-f...
im also planning on useing a lipo batter as i fly rc and i have a charger at home
