85Views5Replies
Author Options:
electrical question Answered
How do I rewire the power cord to a Thermadyne 38 plasma cutter power switch, not having a cord to begin with?
NachoMahma
NachoMahma
10 years ago
.  For 120VAC, the hot wire will go to the switch and the neutral will be connected to a neutral terminal of some sort.
caarntedd
caarntedd
Answer 10 years ago
A double pole switch, and he doesn't know which terminal is active and which is neutral?
tamban282
tamban282
Answer 10 years ago
Alas!! the brother electrican finally called back. Thanks for the input........
NachoMahma
NachoMahma
10 years ago
. Find the cutter's dataplate and determine how much current the unit pulls. Search the web for "AWG ampacity chart" to find out what size wire you need. Obtain the proper size and length cable. Wire as per the old cord.
NachoMahma
NachoMahma
Answer 10 years ago
. Oops! Since you don't have the old cord, see if you can find a manual for the cutter online.
