109Views9Replies
Author Options:
hi , im making a refractor telescope , so can i use a objectivelens with focal lenght 2000mm and eyepiece as a 10mm lens Answered
Tags:space
rickharris
rickharris
7 years ago
Steve will really be the man to answer this BUT:
Your calculation is correct - for a reasonable image you need to have a large diameter objective. This gathers more light and allows for stopping down to reduce chromatic aberrations which will appear unless you use a complex lens system.
Do you intend this for Astro use or terresterial?
steveastrouk
steveastrouk
Answer 7 years ago
Yes, you need a "doublet" for the objective ideally.
pnag1
pnag1
Answer 7 years ago
sir , could you please post a plan on how to make this telescope
steveastrouk
steveastrouk
Answer 7 years ago
What lens have you got access to ? What diameter ?
CabbitCastle has provided a most excellent link. I suggest you read it.
CabbitCastle
CabbitCastle
7 years ago
Generally speaking, yes.
If you wish to build a refracting telescope made of two lenses, the bigger one should have higher magnification (2000mm) and the smaller one a smaller magnification (10mm).
Nasa has a page explaining how to build such a telescope. It also states that you need a certain type of lenses, namely both have to be converging/convex.
Here's some additional links you might want to check out:
American Museum of Natural History (you can use these instructions for a simple assembly to test your telescope)
Roger Ceragioli 's Refractor Construction Page (very detailed and skimming over it, a bit complicated)
pnag1
pnag1
Answer 7 years ago
so , can it give me a magnification power of 200x
CabbitCastle
CabbitCastle
Answer 7 years ago
According to this site, yes.
The formula for magnification of distand objects using a refraction telescope goes as this: Magnification = Objective lens focal length / Eyepiece lens focal length.
I do not know how the size of the lenses plays into this though, I have seen some information suggesting it factors in as well.
steveastrouk
steveastrouk
Answer 7 years ago
The resolving power of the scope (and the image brightness) is "controlled" by the diameter of the objective lens - we reckon a good telescope, in the best seeing can probably manage 50X per inch of aperture, so to get 150X from a scope, you need 3 inches minimum.
pnag1
pnag1
7 years ago
i want the telescope for astronomical use , so the lenght of telescope would be 2000mm +10mm that is 2.1 metres
steveastrouk
steveastrouk
Answer 7 years ago
2.01, not 2.1 long. Much depends on what diameter the lens you have is.
