2006Views6Replies
Author Options:
how can i make a good bike generator for my bike? Answered
nagutron
nagutron
Best Answer 12 years ago
If you have modest power requirements for gear on your bike (e.g. lights), then I agree with Adrian and omnibot's recommendations, below. Most of those generators use a dynamo (a wheel that contacts the rear wheel of the bike, drawing some power through friction.)
The problem with these is that they can be heavy, make noise, add moving parts, and add friction to your ride. A much smoother, quieter solution is simply to use magnetic induction. This will work well if all you need is a little power for LED lights. I just finished an instructable showing how I did this on my bike (it uses a commercial product, but I also link to DIY versions in step 2):
https://www.instructables.com/id/Magnetic_Induction_Bike_Lights/
Good luck!
goodgnus
goodgnus
Answer 12 years ago
To be honest, while I love DIY and power generation, Lion rechargeables are really the way to go for bicycle lighting. Your average dynamo (generator) won't generate enough voltage nor continue to supply power while stopped (unless a capacitor is used) to be effective for safety lighting. When it comes to bicycle lighting and safety it's "the brighter the better" and you certainly won't get that from a dynamo.
nagutron
nagutron
Answer 12 years ago
There's plenty of power in a moving bicycle to shine even super-bright LEDs. The question is just how much drag you want to feel while biking. The Reelights in my instructable, above, are just safety lights. That is they make me very visible to cars, but don't really illuminate the road in front of me. At this level of power draw (and the efficiency of induction rather than a friction-powered dynamo), the drag on my bike is pretty much unnoticeable.
Redrockers
Redrockers
12 years ago
use an old motor- connect the spindle to somthing round like a bottle top and then connect that to the tyre!
goodgnus
goodgnus
12 years ago
To generate power for lights? To use your bike to generate power for other devices? You'll need to clarify your question.
