95Views5Replies
Author Options:
how do I open the vac 420 to get inside. I have removed all the screws but still find it difficult? Answered
tgferreira184
tgferreira184
7 years ago
Use a flathead screwsriver gently to pry it apart. Start at one corner and continue. If it doesn't open somewer that's becouse there is probably a screw somewere nearby.
anne mckenna
anne mckenna
Answer 7 years ago
you've got it right...I did just as I was told with the flathead spanner with no luck....there's a couple of very small covered up possible screws that I have still to investigate/
Many thanks for your help.
Anna
mpilchfamily
mpilchfamily
7 years ago
Check under labels and rubber feet. You may have missed a screw or 2. Also the case may snap together.
anne mckenna
anne mckenna
Answer 7 years ago
thanks for your answer...had a look and there's nothing under the rubber feet or labels
anna
mpilchfamily
mpilchfamily
Answer 7 years ago
Then the case snaps together. So take a flat blade screwdriver and start carefully prying it open.
Kiteman
Kiteman
Answer 7 years ago
+1
