82Views5Replies
Author Options:
how to reduce current ? Answered
We designed a circuit . But it is drawing 70mA of current. I want tot reduce it for atleast 30-40mA.
iceng
iceng
4 years ago
Put this simple circuit into the wire and it will reduce the current to 30 ma...
Your entire circuit must be less then 35 VDC and you may need to use a TO-220 size LM317 regulator if the small TO-92 gets too hot.
Be sure to click on the picture to see the whole image...
And be sure to give someone a Best Answer..
-max-
-max-
4 years ago
Redesign the circuit... or reduce voltage powering it maybe?
Downunder35m
Downunder35m
4 years ago
No comment....
All said already...
Josehf Murchison
Josehf Murchison
4 years ago
schematic schematic schematic
otherwise use a bigger resistor.
bwrussell
bwrussell
4 years ago
Without a circuit diagram there is no specific advice that I can offer.
If it's drawing 70mA of current then it is using 70mA of current. To reduce it you need to reduce the load. For example, if this is an LED circuit then you will need to remove an LED.
