2267Views7Replies
Author Options:
need circuit diagram for a sin wave inverter? Answered
good day honorable members
pls can anyone help me
i want to build an inverter and i need a circuit diagram for an 50Hz 24v to 220v sinwave inverter.
Pls can anyone suply me with an circuit diagram for an 2KVA and a 5KVA inverter
pls pls help me
thank you in advance
iceng
iceng
8 years ago
You don't know what  you are asking for :-(
This points to one of the related near sine wave inverters.
If you can build it,
then you know it will work on 24vdc and
by selecting a bigger transformer with ten parallel power transistors
You can begin to approach what you seek.
You know what heatsink grease ( white sh_t ) is and what metal to use.
A
rahvin1223
rahvin1223
Answer 8 years ago
Good day iceng
thankyou very much for your reply i do apreciate it very much
the circuit that yoy pointed to is for a square wave inverter, i need a sinwave inverter. If you could pls give me a sinwave circuit diagam pls.
I know what heatsink grease is, but not the metal that i need to use, pls could u tell me what i need to know.
Thank you very much
iceng
iceng
Answer 8 years ago
Yes PWM is a better method as Steve points out.
.........You will need ;
  • To loose the simple inverter circuit..
  • Skill with a micro processor,  Micro-chip has one for easy inverter PWM driving.
  • You still need high current inductive components to translate 24VDC to 220VAC..
  • A semiconducting transistor capable of high speed switching  at 240 amperes per inverter circuit leg...
  • A set of two or four devices depending on circuit strategy your final design selects to use..
  • That 240ADC is 5KW reflected back to 24V at 85% efficiency..
  • A 24VDC power source capable of 240ADC..
  • Heat sinks capable of cooling 720 watts that is the energy lost to heat at 85% efficiency...
  • Some pretty good building skills.
Now see what you you were asking ?
And do you know about  best answers ?
A
rahvin1223
rahvin1223
Answer 8 years ago
wow that is a lot to consider, and i do want to learn all how to do all of this. pls help me to understand everything that u are talking about pls, i am new to all of this and i realy want to learn it. no i do not know about best answers.
iceng
iceng
Answer 8 years ago
microprocessor will take 1 to 3 yrs
elementary power semiconductors are a semester at Devry
I test your intellect :-)
A
rahvin1223
rahvin1223
Answer 8 years ago
thanx for the link to devry, i will have a look at it and see to maybe take an online course form them. I have done my N3 in industrial electronics a while back that can help me in my indevor to build the inverter, i hope. can u perhaps help me with some meterial about elementary power semiconductors or in microprocessors pls that can help me to learn about it,PLS
steveastrouk
steveastrouk
8 years ago
THE way to do it is with a phase shifting H bridge, driven by sinusoidally varying PWM.
A.'s method is fun, but I think the formfactor for the resulting sine wave will vary too much WRT load.
Have fun !
