212Views4Replies
Author Options:
solar cells can someone instruct me where to put the diode pos or neg .in the panel or down stream thanks ? Answered
Tags:solar
AndyGadget
10 years ago
It doesn't matter which side of the solar cell it goes, as long as it's pointing in the right direction. If it's connected to the +ve of the cell, the band should be AWAY from the terminal. If you're after every last bit of voltage from it, It's best to use a schottky or germanium diode. Normal silicon ones will work but the other types give you around 0.4v more to the circuit.
AndyGadgetAndyGadget
Answer 10 years ago
Usually, it goes before any other circuitry to prevent your rechargable battery discharging through the panel in low light conditions.
seandogue
10 years ago
technically, it should be located downstream of the panel. There's usually a bar graphic on the diode to show where it's cathode is. That's the side that gets hooked to the load, the other side to the solar cell's + terminal. diode.jpg Agree with Andy on the selection of diode to be used. The lower the diode drop, the better.
