1264Views7Replies
Author Options:
the motor driver L293D controlling the direction of motor, i want to use limit switch to control two position of motor Answered
I am developing a automatic gate project. I want the DC motor stopped as soon as the gate closed or opened completely. I use IC L293D to control the motor forward or backward. This project is also using Arduino. I plan to use a limit switch to control the movement of  DC motor.
iceng
3 years ago
Just to demo the other way, or maybe to prevent motor stall burn out when the micro goes to La-la land ! .
FarhanJiceng
Answer 3 years ago
thanks a lot! it works...I've simulated the circuit, but the motor can only rotate in one direction and not in the other direction. after changing direction diode then I can drive the motor in two directions, and limit-switch works as well as I wanted.
icengFarhanJ
Answer 3 years ago
You are correct !
Please tell me, what is the name of your simulation software.
L293D-1open.JPGL293D-2open.JPGL293D-3close.JPGL293D-4close.JPGL293D-5close.JPGL293D-6close.JPGL293D-7open.JPG
FarhanJiceng
Answer 3 years ago
im using Proteus 8
FarhanJ
3 years ago
the simple simulation circuit i made
rickharris
3 years ago
Feed limit switches into digital inputs on Arduino.
Then use software to control the barrier.
From your diagram if pin 2 is high and pin 7 low the motor turns 1 way - if pin 2 is low and Pin 7 high it turns the other way.
if pin 2 and 7 are both high or low the motor stops.
FarhanJrickharris
Answer 3 years ago
thanks a lot sir. very helpful idea! ☺
