139Views6Replies
Author Options:
wich is input and wich is out put? Answered
On a hand wound transformer for a joule thif wich is the input and wich is the output primary in? secoundary out?, also does it matter if the thick wire (primary) is on the bottom with the thinner (secoundary) is on the top?
iceng
iceng
Best Answer 6 years ago
See my pics.
The thicker wire is the output and technically considered the secondary.
Who's on top matters very little.
In most production transformers the thicker wire is wound on top to prevent mechanical damage to the fine wire.
See the four winding styles each is done for a particular advantage.
bushman9
bushman9
Answer 6 years ago
Thanks for your input! I shall correct my errors. I have another question if you dint mind, If I use 3. 100 ohm resistors all in series will that give me the 300 ohm resistance I want?
iceng
iceng
Answer 6 years ago
Yes three 100 ohm resistors in series, simply add up to 300 ohms.
While you are at it if this was helpful, a click on the best answer would be appreciated.
BTW three 100 ohm resistors in parallel are 33 1/3 ohms.
bushman9
bushman9
Answer 6 years ago
Thank's again! I clicked on that best answer I'm new to all this stuff and am learnning on my own, so I ask kinda dum questions thanks for your answers. what does clicking best answer do??
iceng
iceng
Answer 6 years ago
Braggin rights :-)
