Introduction: NAZI ZOMBIES: Redone
https://www.youtube.com/watch?v=1shEdlJF-OU
up above this sentence is where I got the inspiration for this instructable, please mark as a favorite!
Step 1: Getting to Klaus's Workshop
first, you must unlock the gate to the town square and go to the first alley on the right. there you will find the first valve for the gas. turn around if you are facing the valve, if you are facing the alley go forward a bit and turn to your left. in Klaus's workshop there are tables filled with stuff. on the table near the hole in the wall you might find a little thing that looks like a old recorder. shoot it. it is one of many recorder files hidden on this map.
Step 2: RECORDER FILES.
the first recorder file is near the quick revive at the end of the alley you start at. the second is at the lightning tower. go to where the disposal tube is at. face it and turn right. walk forward toward the cage like window. look on the sill of the window. there should be a recorder there. most of this stuff will NOT show up offline. I can not find a photo of the recorder but I found a link to all of the locations
https://www.youtube.com/watch?v=Xx4TziKQTbs
Step 3: How to Get Pack-A-Punch
first, clear the sewer from all pests. then as soon as you drop down turn around. there will be a gate. open the gate & look around for a button. if the button says open the disposal tubes, open it. if not, do not press it. three tubes will open. the first is located at the lightning tower, go down that & press the button in the cage. it will slightly lift the spiky cage in the middle. the second is in the main bunker room. located to the right of the entrance to the main bunker room is the tube. repeat the same thing as the lightning tower. the second one is located in the laboratory on the right of the bunker's main room. repeat the same as the other two. go to the Pack-A-punch station. get the weapon and the 5,000 jolts needed to upgrade your weapon
