3374Views2Replies
Author Options:
12v dc nichrome electric heater Answered
hi friends
i want to make electric heater that could give sufficient heat with 12 volt dc battery.
how much nichrome wire in lenght should i use and how much gauge of nichrome wire should i use.
i love for your kind replies.
love u all
Tags:heater
iceng
1 year ago
https://en.wikipedia.org/wiki/Nichrome
This article has the tables you need to design a nichrome heater.
First design rule, you want to to stay well below the melting point 1400 C..
Table # 3 tells us you get 400 watts from a 22 AWG wire at 30 ohms and 120 volts that works out A=120/30 = 4 amperes of current.
Now if we want 4 amps at 12 volts the wire resistance would have to be R=V/A
R=12/4= 3 ohms one tenth of the 120v length only P=V*A=> 12 watts and that is too small !
Back to table # 3 where 1400 watts at 8.8 ohms AWG 15 which works out to A=V/R=120/8.8=14 amperes.
Power of about 9 amps at 12 volts A*V = 9x12 => about 108 watts with a new R=V/A=12/9=1.3ohms.
Now in table # 2 we see a 15 AWG nichrome wire will be about 300 C at 9 amperes..
You need to measure about 1.3 ohms of this wire use wire screws solder does not work use a threaded bolt and nut.. Don't cut until you try it and don't burn yourself !
https://www.walmart.com/ip/Nichrome-80-Heating-Ele...
Trial and error does it...
icengiceng
Answer 1 year ago
Split bolt lets you connect copper wire to nichrome wire.
