112Views2Replies
Can anyone tell me what this is called?
I watched a video where they lifted a concrete slab with this tool. I have looked but can't fine the name of it or where it is sold. Just the orange part of the tool. Any help would be appreciated. Thank you.
1 year ago
I have seen these tools in a few variations but never any that came from a shop.
Around here people buy a cheap engine crane and use the parts to make them.
Another way of conversion that I have seen uses a high lift jack for 4WD's.
Top extends to whaere you have the stamp on the concrete, the actual lifting part has a slide on hook to go under the load and at the end you place a small hydraulic jack.
As said, seen a lot of the variations but never something that appear to be bought in a shop.
1 year ago
Think it is called a toe jack.
Bear in mind that they also used a pressurized expanding foam in the drilled holes to spread the lifting load and provide a decent bedding.
ie if you're just going to lift a corner, you might crack the slab.
1 year ago
I watched that video too. Took me awhile to figure out what they were actually doing. It's probably a specially designed tool for the trade. You might be able to have something like it made by a welding shop.
