275Views7Replies
Author Options:
Can i control the time wich a relay turns on without using a programable ic? Answered
Hello guys im building a project but i have an issue i need it to keep the current flowing for 5 secs to turn the relay for 5 secs i mean i press n release the button and the relay keeps on for 5 secs i dont have acces to pics and yet i do have arduinos but im not gonna spend an arduino for a project that means only 1/4 of my grade... thanks
appolo
appolo
Best Answer 11 years ago
Use a transitor to control your relay place a 1k_4.7k resistor inseries with the base and use an electrolytic cap to release it's charge into the base via the series resistor. this will hold the base ON for a period depending on the value of the cap and keep the relay energised. Experiment to achieve the ideal timing point. Nice and simple, place a diode across the relay coil anode to transistors collector, cathode to positive supply side of relay coil.
cupnoodles2
cupnoodles2
11 years ago
thanks every one ;D hes answare seems to b a pretty eassier for me but thanks for the other answares :D
AndyGadget
AndyGadget
11 years ago
You need a 555 timer in monostable mode. <a href="http://www.doctronics.co.uk/555.htm#monostable">THIS</a> is a circuit which will give you exactly what you need, and it also has the formulas to calculate the time delay.<br />
orksecurity
orksecurity
11 years ago
Sounds like a classic application for a 555 timer chip...
steveastrouk
steveastrouk
Answer 11 years ago
I agree. Long accurate delays can be a bit of a problem for the 555 though.
Zengineer1618
Zengineer1618
11 years ago
There are two instructables on how to use the timer from a microwave.
sound91
sound91
11 years ago
 I would just play with capacitors until you find the correct value to hold the relay for the wanted amount of time.  Just place it in parallel with the power that holds the relay the open.
