7862Views9Replies
Author Options:
How to Control a Servo? Answered
How do you control a servo? I know you can control it via Arduino or some other microcontroler, but can you control a servo with out the need of programing??? I know the servo has 3 wires red, black and yellow... and if what I heard is right, that yellow wire is for controlling it.... Thank you! Comodore
charlieCG
charlieCG
12 years ago
the leads of a servo are capable of plugging directly into a receiver. and the receiver can be paired with a transmitter. this requires absolutely no programming and allows you t have manual control over its movements. i use spectrum. this also has the advantage of having wireless control over the servos. http://www.youtube.com/watch?v=4PVhHIuxTsU&feature=related
comodore
comodore
Answer 12 years ago
Thanks charliegwathney!!!
impellbm
impellbm
Answer 11 years ago
so im building a generator with an alternator a lawnmower engine and car battery for onboard power. How can i control the idle via a servo and (i guess a comparator,ic... ) Anyone who knows about robots please help a guy out thanks! -Brian
charlieCG
charlieCG
Answer 11 years ago
Is there some kind of rocker arm or something that controls the throttle?
Derin
Derin
Answer 11 years ago
Yes,there is a small lever which you pull to increase the throttle.
charlieCG
charlieCG
Answer 11 years ago
just attach a rod to the arm of a servo. then attach the other end of the rod to the lever on the motor. if you would like a picture i could probably find a picture of a couple examples on old airplanes of mine.
impellbm
impellbm
Answer 11 years ago
Haha I got that part, i need the servo to react to the voltage level and turn down when the voltage is up and up when the voltage is down. I have an alternator with an internal regulator which allows me to cut the alternator but id like to throttle down as well. Thanks for everyones input!
mrmerino
mrmerino
Answer 8 years ago
I think they make Voltage-to-frequency converters. I don't exactly know where to look, but you could just Google it. The LM231/LM331 might be a good place to start.
tdaly2
tdaly2
Answer 8 years ago
some photos would be good thanks
