14909Views3Replies
How to create a basic save/open file dialog in Visual C#?
I am creating a simple Sticky Notes application that will open/read/save text files (in a *.sticky) extention. I was able to code the entire application, except for the save, save as, and open commands. Does anyone know how to do this?
Thanks.
9 years ago
That should be about it. Hope this helps! -gian
9 years ago
That seems like a lot of code for a save/open function
it might be able to be simplified
9 years ago
I have learn C# for 2 years, i can help you, it's really easy, this is the code:
private void openToolStripMenuItem_Click(object sender, EventArgs e)
DialogResult result = new DialogResult();
if (kiemtrasave == 2)
result = MessageBox.Show("Click Yes to Save or Click No to Exit", "Warning", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Warning);
if (result == DialogResult.No)
openFileDialog1.FileName = "";
if (openFileDialog1.ShowDialog() == DialogResult.OK)
richTextBox1.LoadFile(openFileDialog1.FileName);
this.Text = cap + ": " + openFileDialog1.FileName;
else if(result == DialogResult.Yes)
if (path != "")
saveFileDialog1.FileName = path;
richTextBox1.SaveFile(saveFileDialog1.FileName);
kiemtrasave = 0;
this.Text = cap + ": " + saveFileDialog1.FileName;
path = openFileDialog1.FileName;
kiemtrasave = 0;
else
if (saveFileDialog1.ShowDialog() == DialogResult.OK)
kiemtrasave = 0;
kiemtrasave = 0;
else
kiemtrasave = 0;
private void newToolStripMenuItem_Click(object sender, EventArgs e)
result = MessageBox.Show("Click Yes to Save or Click No to Create a New text", "Warning", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Warning);
if (result== DialogResult.No)
richTextBox1.Clear();
this.Text = cap;
kiemtrasave = 0;
if (path != "")
this.Text = cap;
kiemtrasave = 0;
else
kiemtrasave = 0;
path = saveFileDialog1.FileName;
else
path = "";
this.Text = cap;
kiemtrasave = 0;
private void saveToolStripMenuItem_Click(object sender, EventArgs e)
if (path != "")
kiemtrasave = 0;
else
kiemtrasave = 0;
private void saveAsToolStripMenuItem_Click(object sender, EventArgs e)
kiemtrasave = 0;
this application for my examination
note: kiemtrasave is variable that you check the richtextbox saved or not
0 is saved.
