7330Views5Replies
Author Options:
How to make a plank floor out of wood pallets for a mobile home? Answered
Need step-wise process on how to make a wood floor out of wood pallets for a mobilehome. I have a wood sub-floor?
leo.valdez.5074
5 years ago
do i need to put a tongue and groove on it if i'm laying it on concrete
steveastrouk
10 years ago
Like Lemonie says, but if you can beg borrow or steal a planer thicknesser you'll get a better result faster. You have to be absolutely paranoid about nails in the old pallets whether you sand or plane - but a planer will make all your boards consistently thick, and you will need only a skim with a sander to bring up the final surface. One kicker to note is that pallet nails are often ring shanked and glue coated pulling them can be REALLY hard.
orksecuritysteveastrouk
Answer 10 years ago
Nails -- or bits of fence or other inclusions -- are always a lurking hazard to a planer. There are small metal detectors available which you can use to do a pre-scan; if whoever you're borrowing the thickness planer from has one they'll probably _insist_ you borrow it too, to protect their tool. If they don't, you might want to buy one yourself (they aren't all that expensive) , and if you don't need it after the project is done give it to them as "rent" on the machine. I hate wasting (sometimes surprisingly nice) hardwood... but if I was in a hurry, I'd be tempted to just cut away the nailed sections.
steveastroukorksecurity
Answer 10 years ago
The idea of wasting the wood I hated so much I didn't suggest it :-) Perhaps I ought to write up a passthrough metal detector as an instructable..... My dad used to design them nearly 50 years ago to detect a pin head in a bale of cotton.
lemonie
10 years ago
You need to pull the pallets apart, it's a foot on the bottom, and pull the top action. You might find it helps to pry them apart with a bar, or knock them a part with a big hammer. Once you've done that you'll have nails sticking out of the planks, tap the sharp ends with a hammer so that the come out backwards. How you lay the planks is up to you and your existing floor. You'd then want to run a sander over the floor and varnish it. L
