110Views13Replies
Author Options:
I have a ceder chest that i cut a hole in the side for my outside cats.how can i heat it for the winter??? Answered
Tags:cat
Re-design
Re-design
Best Answer 11 years ago
I'd go for the blankets inside approach and add a flap of fabric over the door to block the breeze.  Cats and dogs both survive very well outside if they are dry, have something warm like hay or blankets to curl up in and can get out of the wind.
Be better all around if you just brought them in and made them inside cats.
bigmark
bigmark
Answer 11 years ago
If they would use the litter box i'd put in a doggy door.
Re-design
Re-design
Answer 11 years ago
I've never had a cat that once shown the litter box that they wouldn't use it.  I guess i've just been very lucky.
AngryRedhead
AngryRedhead
Answer 11 years ago
Seconded.  Flap + Bedding = Warm
seandogue
seandogue
11 years ago
there used to be a plugin heater tape used for roofs to keep down ice dams that might be applicable, although I'm not sure where to get one these days...hardware stores? they used to be common. My older brother used to have one wound around on the floor of his cold-frame to reduce frost damage.
steveastrouk
steveastrouk
Answer 11 years ago
"Trace heating tape"
HTH
Steve
seandogue
seandogue
Answer 11 years ago
HTH?
My netlingo skills are lacking I see. ;-)
artquilter
artquilter
Answer 11 years ago
Hope That Helps
seandogue
seandogue
Answer 11 years ago
Ahh......ty it does!
RavingMadStudios
RavingMadStudios
11 years ago
In the same vein as the electric blanket, there's also the electric heating pad or the reptile cage "Hot Rock" approach. Same basic idea, slightly different application.
jtp139
jtp139
11 years ago
you could try the electric blanket on a timer switch. But I think maybe if you just line the box with blankets it should be alright.
steveastrouk
steveastrouk
11 years ago
There is of course an 'ible on it. This guy used a string of rope lights !
https://www.instructables.com/id/Cat_House/
Steve
5150tech
5150tech
11 years ago
I know someone who uses an electric blanket. I make no claims as to the safety or wisdom of such things.
