181Views6Replies
Author Options:
I want to slow down a electric motor on a dishwasher timer. Answered
Motor is 115v 3w ac . With low water pressure the timer shuts off before enough water enters to wash well. Their is an over fill safety so I don't need to worry about that. I realize that this will also increase all function times but that is ok. Thank you.
bngeohealth
bngeohealth
9 years ago
Thank you for your answers. My electronics are not great but I can follow instructions. I looked at frequency generators but could not find plans for such a small motor. The water pressure in the house is consistent throught so some times the washer works fine but we are not always aware of when thier is a pressure drop unless we use the water. Took a while to figure out because the problem was intermintent . A booster pump ? Maby but seems elaborate. Now looking to modify cams on the drum to hold the contacts closed longer. This may be easier than a frequency modulater unless a 55hz modulater for a 3w motor is easier?
steveastrouk
steveastrouk
Answer 9 years ago
ANOTHER way to do it, would be to put a stepper motor on the timer....The body style of the motors used is the same between an AC motor and a stepper - in fact, you can use a stepper directly (the correct) AC volts. Then the signal generator need only be very, very basic to get what you need.
Steve
steveastrouk
steveastrouk
9 years ago
Its not an easy thing to change the speed of. The BEST way is to drive the timer on its own from a different frequency supply - like say, 55Hz, instead of 60Hz.
You can't run these motors at a different voltage and get a change in speed - well, you can, a little bit, but you lose power from the output too, and it will stall (and burn)
Making a thing to give you an adjustable frequency though, at mains volts, isn't easy. How's your electronics ?
Steve
frollard
frollard
Answer 9 years ago
+1
Perhaps consider adding a booster pump in parallel with the 'input water' solenoid; boosting the pressure might get you a little more water in there.
Also consider the lines /valve might be crudded up and a simple descaling might be in order to get that flowrate back up.
steveastrouk
steveastrouk
Answer 9 years ago
Pumping though implies there's stuff to pump: the OP needs to check the water at their incoming pipe I suppose.
Steve
frollard
frollard
Answer 9 years ago
true, but the flowrate of an open dishwasher valve still isn't very high at all. Agreed on checking pressure for the rest of the (presumably) house.
