78Views5Replies
Author Options:
Type of sensor in automatic scooter's speedometer? Answered
So, which Type of sensor's is in scooter's speedometer. i've got a bunch of wires i've identefied all of them, only 2 are left, which one connected to a voltameter shows no hike in voltage when scooter is moving...... so which type of sensor is that.
Downunder35m
Best Answer 2 years ago
On petrol machines it is usually done through impulses from the ignition or by the means of a sensor mounted to the wheel, drive shaft or ignition rotor.
In most cases there will be a magnetic sensor on the front wheel.
Put the thing on a milk crate or similar, turn the ignition on and spin the wheels by hand - if you see a speed you know where to find the sensor.
petercd
2 years ago
Probably a hall effect sensor, if its a lcd speedo.
_Boltz_petercd
Answer 2 years ago
No it's analog typo i think so...... my scooter is "Hero maestro" search it ..... and you'll be able to figure out.......
petercd_Boltz_
Answer 2 years ago
Usually an analog speedo is driven by a rotating cable off a gear on the front wheel, but if has no cable drive then its anybodies guess.
_Boltz_petercd
Answer 2 years ago
no there was a cable , and i guess it'll be a hall's sensor ..... i'll be tinkering on it by saturday again.......
