908Views14Replies
What is the best 10mm LED light for distance?
HI
I'm making a LED torch and i have purchased some 290000 mcd LED lights.I think i will put them in a ring inside the torch which will allow me to see clearly in front of me.Then i thought i could put a long distance light in the middle would allow me to see out further but i am unsure of what LED light is best for this task.Basically i am after a LED light that shines really far.
9 years ago
Get a bright narrow angle LED, here, the narrower the better.
Answer 9 years ago
okay were would i find one of them online.
Answer 9 years ago
See my later reply
Answer 9 years ago
Narrow angle remember - Google "super bright leds"
L
Answer 9 years ago
Is this light any good?
http://www.superbrightleds.com/moreinfo/component-leds/cree-xre-series-1-watt-white-led-wg-q4/905/
Answer 9 years ago
Its "bright", but the viewing angle is 90 degrees. You want the same lumens, but more candela, or you want to add one of these. http://www.superbrightleds.com/moreinfo/component-leds/cree-xr-series-xlamp-lens/330/
Adding a lens to the LED is a VERY good way to get more bang for very little actual buck. If you take a 90 deg beam, and squirt it out as a 15 deg beam, it will be 36 x "brighter" - since the area illuminated by the beam is 36 x smaller.
Steve
Answer 9 years ago
Do you what any good lights are?
Answer 9 years ago
Not really, only what I have for what I use and I've not built powerful lamps/torches.
L
Answer 9 years ago
+1
Answer 9 years ago
That looks like a nice LED light what is it and where do you get it?
9 years ago
It's a narrow beam 10mm 0range LED used in my
https://www.instructables.com/id/POCKET-THIEF/
instructable 36 Candle Power.
A
Answer 9 years ago
how far does this light go clearly do you think?
Answer 9 years ago
I can plink reflectors across the street.
9 years ago
Brighter = further as long as the beam is narrow. hence Steve and Iceng advice.
I believe it may be worth experimenting with a cheap LED with flattening the end almost to the die (the bit that is the LED) The polish the end smooth and put a standard lense in from for focus.
DO AT YOUR OWN RISK with costly high power LEDS as I have not tied this.
There are LED suppliers that supply lens kits to go with LEDs.
example
http://www.rapidonline.com/Electronic-Components/Optoelectronics/LED-Optics-Mounts
