294Views4Replies
Author Options:
foot pedal controlled glue gun? Answered
I would like to have a glue gun mounted on a stand and controlled with a foot pedal so both hands are free. Any ideas on how to do this?
Downunder35m
Downunder35m
4 years ago
Usually they operate onmains power, so just make a small box that holds a switch, power socket for the glue gun and on top a rod that goes onto the switch.
If you want to go fancy replace the switch with a capacitve sensor and relay.
baker_eliz
baker_eliz
Answer 4 years ago
Thanks, Downunder35m, I appreciate your taking the time to respond, but I'm afraid my knowledge is not up to your suggestion. I don't have a clue what you are talking about. If I have instructions I can usually follow them and figure things out as I go, but this isn't quite enough for me to go on.
--elizabeth
Quadrifoglio
Quadrifoglio
4 years ago
For those with deep pockets:
https://www.hotmelt.com/blog/hot-melt-dispensing-systems-using-a-foot-pedal.
https://www.gluegun.com/collections/pneumatic-glue-guns
A mechanical carburetor actuator system would work as a model. You would have an accelerator pedal on the floor. Motion from the pedal would be transmitted via a mechanical cable. The motion would be received by a spring return trigger linkage, some cables have a spring built-in. The spring loading is important so that the trigger returns to zero so that you can continue to feed the glue stick. You would also need a glue gun stand.
The drawing gives you an idea of the model. However, as they say, the devil is in the detail.
baker_eliz
baker_eliz
Answer 4 years ago
Thank you for taking the time to send this link my way. This is kinda what I'm looking for but a little too rich for my pocket and much more sophisticated than I need. I'm a hobbyist and only use a glue gun occasionally. I was hoping someone had already made an instructable for this, but it doesn't look that way.
Thanks, again, Quadrifoglio.
--elizabeth
