103568Views8Replies
Author Options:
mower starts when cold, stalls when hot. has been tuned up, can it be the coil? was told that it was wet gas Answered
Mechanic said that it was water in the gas... the tank has been emptied, the carb cleaned, new plug, and new blade. It still stalls after about ten minutes of running, and then may start back up when it's cold.... I've been thinking that it is a coil problem.. That's the only thing left unchecked because it fired up at the shop , so they sent it home.... And I am curiouse to know a safe way to check a coil while the engine is hot... I have a multimeter, I just don't know how to use it on a coil , or what readings I may be looking for. Thanks for any advice I can get Slacker
lilbit1970
lilbit1970
1 year ago
I have a turf tiger scaggs with a 27 horse Kawasaki it runs for about 10 minutes and then quits running at that time it is not firing I have replaced the coals replace the plugs replaced the fuel pump I have also clean the flywheel the magnets Not sure what else it could be
horseman43
horseman43
2 years ago
It sounds like it could be the gas cap vent, check the cap there is a vent in it. try starting and run with the cap loose to vent it, if it works clear the vent holes in it. to check the coil would be to ground the plug to the block and look for spark, but it really sounds like cloged vent Good Luck.
KennethM138
KennethM138
2 years ago
I have a kohlor 19 hp that starts up and runs for a minute or so and shuts off. when I let it sit for a while it will start back up but only shut off again when it starts to warm up. I replaced the ignition mod,carb,fuel filter,spark plug air filter and still have the same problem. Put in fresh gas and checked the gas cap. Whats going on , Help
Kauri69er
Kauri69er
3 years ago
hey guys,
Any help would be appreciated. I have a GX200 go kart motor and I am having issues running it after it's warmed up and under load. I have totally stripped and cleaned the carb, cleaned and blown out the jets and ports on it also. I've also replaced the carb gaskets at the same time. I have replaced the ignition coil with a brand new one also sanded the slight rust which was visible on the flywheel magnets. Replaced the spark plug with a new one, replaced the fuel and fuel lines plus fuel filter. Reset the valve clearances and replaced head gasket. At the time I removed the cylinder head the rocker assembly and valves appeared in good condition. I also checked the flywheel key and it was in good condition.
Being the fact it starts and runs, would it be safe to say I can eliminate compression as a fault? I really am at a loss of what else it could be....
I have also removed the fuel cap and it made no difference
RJ7
RJ7
5 years ago
Check the gas cap vent first. It only takes a second. Just when engine starts to sputter, unscrew the cap. My mower started running perfect the second I unscrewed the cap. An interesting twist to this problem is that the more fuel you have in the tank, the less time it takes for a vacuum to develop and starve the engine of fuel. If your tank is half full, it might run for long enough to make you think you have a faulty coil that is failing when hot. If your tank is topped off, it might die in a minute or two, leading you to think it is a fuel filter or carb problem.
HalH7
HalH7
Answer 4 years ago
I have a zero turn Kohler engine lawn mower. Runs fine until it warms up then it seems to be running on only one cylinder. I did check the gas cap. Change the gas filter spark plugs and air filter. Then all the sudden it starts to run good again. Then without warning goes back to one cylinder this goes on and on. I appreciate any information you can give me thank you kindly.
MitchelD1
MitchelD1
Answer 4 years ago
If you find out let me know, I have a 26 hp Kohler that is driving me crazy!
fosterairborne
fosterairborne
7 years ago
Had this problem, took cerberustugowar's advice, was the cap...............that I had traded off another mower 4 months ago when It was doing the same thing and I figured this one out on my own........Im getting old.
cerberustugowar
cerberustugowar
11 years ago
Forsure it can be the coil. But you need a tester that can take the high voltages. The shop that you took it to should have a tester there and it should only take 1 minute. You can also check it yourself. Check it when the mower is cold by removing the sparkplug, putting it back into the sparkplug boot and resting the metal part of the sparkplug onto the cylinder of the engine. Make sure it's a nice strong looking blue spark. Try this same test after the unit has quit on you. If it was the carburator it would be a constant problem. as long as everything was cleaned out and all old gas and debris was removed then it should be good. gaskets and the intake track shouldn't change during heat up and cool down. This would also be a constant problem. If the flywheel key was sheared then the unit would not start or would constantly run poorly. How does the mower stop running, Does it stop suddenly, or does the engine kind of run on and take 2 or 3 seconds to die? I work on small equipment everyday all day. Want to know what my guess is? remove the hose where it connects to the carb, Make sure the fuel is flowing well here. If it's not flowing well then the engine may be burning the fuel faster than it was get gas to the carb. If the fuel flows slowly try to remove the gas cap and see if it starts flowing faster. My initial guess is the gas cap not venting correctly. So if it's running and it sounds like its going to die, try to quickly unscrew the gas cap and see if it picks back up. If nothing works, write back and let me know.
Phil B
Phil B
11 years ago
The voltages in an ignition coil are too high for a multi-meter to handle without damage. Sometimes you can get a feel for whether the problem is related to the fuel system or the electrical system. If related to the fuel system, the engine may stumble before quitting. If related to the electrical system, it is more likely to just quit suddenly. Check the routing of the coil wiring, especially on the primary side, to see if years of vibration have worn away the insulation from a wire and heat causes it to move so it shorts when the engine is hot. You will likely need to remove the flywheel to check the coil wiring. If the engine is stopping after it heats up, it seems something is moving or changing due to engine heat. What about the gaskets on the carburetor, both between the bowl and the carburetor body, and also the gasket between the carburetor and the engine block. If the engine is a few years old, the gaskets may not seal well or the mounting bolts may be loosened slightly. If the engine is older, the float could have a leak and could have become heavy. If the float is plastic it is porous and will also become heavy after a few years from absorbed gasoline. I would also check the engine compression when hot to make sure it is within acceptable limits (around 80 pounds). Is the engine receiving lubrication. If not, the engine could seize and stop. But, it would not likely start when cold until the piston was made free again. In order to run, an engine needs air, fuel, compression, and an ignition spark. If any one of these is compromised, the engine does not run. I hope something in this helps.
frollard
frollard
11 years ago
Indeed - it could be the coil misaligned, bent shear pin (make sure its square), 'new spark plug' - did you make sure it's gapped properly for your engine?
