problem with UDP.print
Hi everyone
my problem is that i want the send 3 sensor data over ethernet UDP in one time
and i don't know the way to do that
thank's for your time
#include <Ethernet.h> //Load Ethernet Library
#include <EthernetUdp.h> //Load UDP Library
#include <SPI.h> //Load the SPI Library
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE}; //Assign a mac address
IPAddress ip(192, 168, 1, 252); //Assign my IP adress
unsigned int localPort = 4000; //Assign a Port to talk over
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
String datReq; //String for our data
int packetSize; //Size of Packet
EthernetUDP Udp; //Define UDP Object
float temp; //temp means temperature
float speed;
float charge;
float dataSend[] = {temp, speed, charge};
int temp_ADC;
int speed_ADC;
int charge_ADC;
void setup() {
Serial.begin(9600); //Turn on Serial Port
Ethernet.begin(mac, ip); //Initialize Ethernet
Udp.begin(localPort); //Initialize Udp
delay(1500); //delay
void loop() {
packetSize = Udp.parsePacket(); //Read theh packetSize
if(packetSize>0){ //Check to see if a request is present
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE); //Reading the data request on the Udp
String datReq(packetBuffer); //Convert packetBuffer array to string datReq
if (datReq =="ordre") { //See if Red was requested
temp_ADC = analogRead(0); //read analog input on pin A0
temp = temp_ADC * 5.0 * 100.0/1024.0; // ADC to celcius conversion
speed = analogRead(1); //read analog input on pin A1
charge= analogRead(2); //read analog input on pin A2
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort()); //Initialize Packet send
Udp.print(temp); //Send string back to client
Udp.print(speed); //Send string back to client
Udp.print(charge); //Send string back to client
Udp.endPacket(); //Packet has been sent
memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE);
