292Views7Replies
Author Options:
can an ordinary fan motor be used as a dynomo in a wind mill generator ? Answered
frollard
frollard
11 years ago
Generally no - presuming your fan is an AC motor.  It needs a loading (self-exciting) capacitor to charge the coils so that the motor sees any magnetic field to generate power with...
If its a DC permanent magnet motor then of course, just turn it and it will produce power :D
steveastrouk
steveastrouk
Answer 11 years ago
+1 ...and the things only really work at their original shaft speed ...
frollard
frollard
Answer 11 years ago
A lot of sources online say you need to go about 10% faster than original speed to compensate for the time it takes for the magnetic field to collapse...another point against using this for wind generation :(
steveastrouk
steveastrouk
Answer 11 years ago
Its more to do with slip speed - the difference between synchronous speed and the actual speed that the motor is doing. In a motoring situation, slip speed is negative. A motor runnning on 60hz whose synchronous speed is 3600 RPM will run at 3500 RPM. Generating, slip speed is +ve, and you'll have the opposite situation, to extract energy, you'll have to turn it at 3700 RPM to get 60Hz back out.
kirdaiht
kirdaiht
Answer 11 years ago
Wasn't it that if you turned it at a lower speed (1000 RPM instead of 3000) you would still get power, only at a much lower frequency?
frollard
frollard
Answer 11 years ago
I never knew that!  I thought the mechanical relationship between the coils would result in an exact requirement for input>output correlation, like cogs in a machine.
I are learned stuff.
steveastrouk
steveastrouk
Answer 11 years ago
No slip - no torque.
I've forgotten a lot - I did a LOT of electric machine theory when I did my degree in electrical and electronic engineering - looking at your profile, about when you were born.
Motors and alternators have a lot of surprises in them.
