392Views4Replies
Author Options:
non UV(A) blocking plastic / lens, any ideas Answered
I'm building a UV(A) 365nm powerLED lamp and need to protect the leds without loosing performance. Does anybody know of a plastic to protect the led without blocking the uv, glass is to fragile (and blocks), it's for heavy use.
lemonie
lemonie
11 years ago
Where are you getting the short(ish) wavelength LEDs? - I'm interested in some myself.
Quartz is great, but it's expensive.
Go with Raving's suggestion of polystyrene.
L
Fonnie
Fonnie
Answer 11 years ago
i'm from belgium, and I found the powerled here at Conrad
http://www.conrad.be/goto.php?artikel=180356
it is 365nm, the problem is the pcb, those i bought at
http://www.led-tech.de/en/High-Power-Supply/Circuit-Boards/MultiLine-Circuit-Board-for-1-3x-LEDs-LT-663_106_111.html
since I needed a lot of power, I need at least 3 led's
combined with a constant current driver
http://www.led-tech.de/en/LED-Controlling/Constant-Current-Power-Supply/BUCK-Constant-Current-Power-Supply--700mA,-30V--LT-1552_118_119.html
lemonie
lemonie
Answer 11 years ago
Thanks.
L
RavingMadStudios
RavingMadStudios
11 years ago
Clear polystyrene is probably the most UV-transparent clear plastic you're going to find.
Polyethylene and teflon absorb less UV than polystyrene, but are not typically found in clear sheets - cloudy is the best you're gonna get..
